Use this procedure to designate a slot in the switch for IOC module preconfiguration. You can designate a slot for only one module type at a time.
The following examples prepare a slot for IOC module preconfiguration:
Prepare a slot for IOC module preconfiguration, with card lock enabled on the slot.
Switch:1>en Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#preconfig slot 5 8624XT lock
Verify the configuration:
Switch:1(config)#show sys-info card
Card Info :
  Slot 5 :
        CardType          : 8624XT
        CardDescription   : 8624XT
        CardSerial#       : SDNI86XSD282
        CardPart#         : EC8604002-E6
        CardAssemblyDate  : 20161125
        CardHWRevision    : D2
        CardHWConfig      : 0
        AdminStatus       : up
        OperStatus        : up
        PowerStatus       : on
        Preconfigured     : yes
        Preconfig CardType: 8624XT
        Preconfig Lock    : yes
            If card lock is enabled on the slot, and the module type of the inserted IOC module does not match the preconfigured IOC module type (for example, if the inserted module is type 8624XT but the preconfigured module type is 8624XS), then the operational status of the inserted IOC module displays as down-Mismatch.
Switch:1(config)show sys-info card
Card Info :
  Slot 5 :
        CardType          : 8624XS
        CardDescription   : 8624XS
        CardHWRevision    : D2
        CardHWConfig      : 0
        AdminStatus       : down
        OperStatus        : down-Mismatch
        PowerStatus       : down
        Preconfigured     : yes
            Prepare another slot for IOC module preconfiguration, with no card lock enabled on the slot.
Switch:1>en Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#preconfig slot 6 8624XS
Card Info :
  Slot 6 :
        CardType          : 8624XS
        CardHWRevision    : D2
        CardHWConfig      : 0
        AdminStatus       : up
        OperStatus        : up
        PowerStatus       : on
        Preconfigured     : yes
        Preconfig CardType: 8624XS
        Preconfig Lock    : no
            If card lock is disabled on the slot, and the IOC module type of the inserted card does not match the preconfigured module type, the existing configuration is deleted and the slot is automatically preconfigured with the module type of the inserted IOC module. The inserted module then boots up with default configuration.
In the following example, when the 8624XT module is inserted in a slot preconfigured for the 8624XS, the pre-configuration for the 8624XS is deleted because it is not locked. The slot is then automatically preconfigured for 8624XT when the IOC module is physically inserted in that slot.
Card Info :
  Slot 6 :
        CardType          : 8624XT
        CardHWRevision    : D2
        CardHWConfig      : 0
        AdminStatus       : up
        OperStatus        : up
        PowerStatus       : on
        Preconfigured     : yes
        Preconfig Lock    : no
The following table defines parameters for the preconfig slot command.
| Variable | Value |
| <1-8> | Specifies the slot number designated for pre-configuration. |
| WORD <1-20> | Specifies the card type that can be assigned to the pre-configured slot. |
| lock | Specifies that the IO card will be locked to the pre-configured slot. Only the IO card that matches the card type assigned to the pre-configured slot will operate. |
