View all of the ACE ARP entries associated with an ACL.
- Click Advanced Filters (ACE/ACLs).
- Click the ACL tab.
- Select the appropriate ACL.
- Click Arp.
- To modify a parameter, double-click the parameter, select the option, and then click Apply.
ARP field descriptions
Use the data in the following table to use the ARP tab.
| Name | Description |
| AclId | Specifies the ACL ID. |
| AceId | Specifies the ACE ID. |
| Type | Specifies the ACE ARP operation. The only option is operation. |
| Oper | Specifies the operator for the ACE ARP operation. The only option is eq (equal). |
| Value | Specifies the ARP packet type. Valid options are arpRequest and arpResponse. |
