View Ping Results
View ping results to view performance-related data.
Troubleshooting using ping and traceroute is not supported on EDM. For more information, see VOSS Release Notes. As an alternative, use CLI.
- From the navigation pane, expand .
- Click Ping/Trace Route.
- Click the Ping Control tab.
- Select a ping test entry.
- Click Ping Result.
Ping Result Field Descriptions
Use the data in the following table to use the Ping Result tab.
| Name | Description |
| OwnerIndex | Specifies the ping test owner. |
| TestName | Specifies the test name. |
| OperStatus | Indicates the operational status of the test. The default is disabled. |
| IpTargetAddressType | Specifies the IP address type of the target. The default is unknown. |
| IpTargetAddress | Specifies the IP address of the target. |
| MinRtt | Specifies the minimum ping round-trip-time (RTT) received. A value of 0 means that no RTT is received. |
| MaxRtt | Specifies the maximum ping RTT received. A value of 0 means that no RTT is received. |
| AverageRtt | Specifies the current average ping RTT. |
| ProbeResponses | Specifies the number of responses to probes. |
| SentProbes | Specifies the number of sent probes. |
| RttSumOfSquares | Specifies the sum of squares of RTT for all probes received. |
| LastGoodProbe | Specifies the date and time when the last response is received for a probe. |
