- Disable ECMP before you configure route preferences.
Change IP route preferences to force the routing protocols to prefer a route over another. Configure IP route preferences to override default route preferences and give preference to routes learned for a specific protocol.
Important
Changing route preferences is a process-oriented operation that can affect system performance and network reachability while you perform the procedures. Therefore, if you want to change default preferences for routing protocols, you do so before you enable the protocols.
- Click IP.
- Click the RoutePref tab.
- In the ConfiguredValue column, change the preference for the given protocol.
- Click Apply.
RoutePref field descriptions
Use the data in the following table to use the RoutePref tab.
| Name | Description |
| DefaultValue | Specifies the default preference value for the specified protocol. |
| Protocol | Specifies the protocol name. |
| ConfiguredValue | Configures the preference value for the specified protocol. |
