View EAPoL session statistics to manage network performance.
Use the clear-stats command to clear EAP/NEAP statistics.
Switch:1#show eapol session-stats interface
                      Eap Authenticator Session Statistics
PORT  MAC                  SESSION   AUTHENTIC       SESSION               TERMINATE       USER
NUM                        ID        METHOD          TIME                  CAUSE           NAME
1/1   18:a9:05:b1:04:ce    cb000000  remote-server   0 day(s), 05:58:16    not-terminated  sachin
1/4   00:00:00:00:00:01    cb000002  remote-server   0 day(s), 05:48:01    not-terminated  000000000001
Use the data in the following table to use the show eapol session-stats interface command.
| Variable | Value |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
