                    Use FTP or SFTP to transfer the OVA image to the /var/lib/insight/packages/ directory on the switch.
Perform the following procedure to configure the package information to be used by the virtual service.
- Select Virtual Service.
- Select the Application tab.
- Select Insert.
- In the Name field, enter the virtual service name.
- Next to the PackageName field, select the ellipsis, select the package to install, and then select Ok.
- Select Insert.
Application Field Descriptions
Use data in the following table to use the Application tab.
| Name | Description |
| Name | Specifies the name of the virtual service. |
| PackageName | Specifies the name and location of the package. |
| InstallResult | Shows the status of the virtual service installation. |
| InstallStage | Shows the stages of a package installation. |
| PackageAppName | Shows the application name used by the virtual service. |
| PackageAppVersion | Shows the application version used by the virtual service. |
