By default, both sides of an IPsec connection are Initiator devices. IPsec Network Address Translation Traversal (NAT-T) connections require that one side of the connection is a Responder device and the other side of the connection is an Initiator device.
If the Responder device and the Initiator device are both behind NAT, the IPsec NAT-T Initiator device requires the public IP address of the Responder device.
Perform the following steps to configure one side of an IPsec NAT-T connection as a Responder device:
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select IS-IS.
  3. Select Logical Interfaces.
  4. Select Insert.
  5. Select IpsecNatConfigResponderOnly.
If required, perform the following steps on the IPsec NAT-T Initiator device to configure the public IP address of the Responder device:
  2. Select IS-IS.
  4. Select Insert.
  5. For IpsecNatConfigRemoteNatIPAddr, enter the public IP address of the Responder device.
Use the data in the following table to use the Logical Interfaces tab and the Insert Logical Interfaces dialog. The available fields in the dialog differ depending on the type of core you select: layer 2 or ip.
Name
Description
Id
Specifies the index number that uniquely identifies this logical interface.
This field displays on the Insert Logical Interfaces dialog only.
IfIndex
Specifies the index number that uniquely identifies this logical interface. This field is read-only.
This field displays on the Logical Interfaces tab only.
Name
Specifies the administratively assigned name of this logical interface, which can be up to 64 characters.
Type
Note:
Exception: Type Layer 2 is not supported on XA1400 Series.
Specifies the type of logical interface to create:
  • Specify layer 2 for a Layer 2 core network that the tunnel will traverse.
  • Specify ip for a Layer 3 core network that the tunnel will traverse.
DestIPAddr
Specifies the destination IP address for the IP-type logical interface.
DestIfIndex
Note:
Exception: Not supported on XA1400 Series.
Specifies the physical port or MultiLink Trunking (MLT) that the Layer 2 logical interface is connected to.
Vids
Note:
Specifies the list of VLANs that are associated with this logical interface.
PrimaryVid
Note:
Specifies the primary tunnel VLAN ID associated with this Layer 2 Intermediate-System-to-Intermediate-System (IS-IS) logical interface.
CircIndex
Identifies the IS-IS circuit created under the logical interface.
NextHopVrf
Note:
Identifies the next-hop VRF name to reach the logical tunnel destination IP.
IpsecEnable
Note:
Exception: Only supported on XA1400 Series.
Specifies whether the logical interface should use IPsec.
AuthenticationKey
Note:
Specifies the authentication key of this logical interface, which can be up to 32 characters.
ShapingRate
Note:
Specifies the value, in Mbps, of the Egress Tunnel Shaper applied to the logical interface.
Mtu
Note:
Specifies the Maximum Transmission Unit (MTU) size for each logical interface. The default MTU value is 1950.
IpsecTunnelDestAddress
Note:
Specifies the destination IP address for the IPsec tunnel.
Note:
When you configure the destination IP address for the IPsec tunnel, IKE protocol uses UDP port 500. However, if IPsec NAT-T is detected, IKE protocol uses UDP port 4500 instead.
BfdEnable
Note: Exception: Not supported on VSP 8600 Series or XA1400 Series.
Enables or disables BFD on an IS-IS Logical Interface.
IpsecResponderOnly
Note:
Specifies whether the device is a Responder device in an IPsec Network Address Translation Traversal (NAT-T) connection.
IpsecRemoteNatIPAddr
Note:
Specifies the public IP address of the NAT router connected to the Responder device in an IPsec NAT-T connection.
Note:
When you configure the IPsec remote NAT IP address, IKE protocol uses UDP port 4500.
IpsecAuthMethod
Note:
Configures the IPsec authentication method for the tunnel as either a pre-shared key or RSA signature for digital certificates. The default is pre-shared key.
CertSubjectName
Note:
Specifies the digital certificate subject name used as the identity certificate.
Compression
Note:
Reduces the size of the IP datagram to improve the communication performance between hosts connected behind Backbone Edge Bridges (BEB).
Tip:
As a best practice, use IPsec compression only for Fabric Extend tunnels where latency is greater than 70ms.
FragmentBeforeEncrypt
Note:
Enables or disables the fragmentation of packets before IPsec encryption on the tunnel. By default, fragmentation before encryption is disabled.
TunnelSourceType
Note:
Specifies the type of source IP address for the IPsec tunnel.
  • global specifies the tunnel source address configured in the IpTunnelSourceAddress field of the ISIS Globals tab.
  • static specifies the manually configured source IP address for the IPsec tunnel.
  • dhcp specifies the source IP address automatically obtained from the management IP assigned through DHCP.
The default is global.
TunnelSourceAddress
Note:
Specifies the source IP address for the IPsec tunnel.
TunnelVrf
Note:
Specifies the VRF name associated with the IPsec tunnel.
Esp
Note:
Specifies the Encapsulating Security Payload (ESP) cipher suite for IPsec.
  • aes128gcm16-sha256 specifies the AES cipher with a 128-bit encryption key and GCM block mode.
  • aes256-sha256 specifies the AES cipher with a 256-bit encryption key and CBC block mode (for QAT performance mode).
  • aes256gcm16-sha256 specifies the AES cipher with a 256-bit encryption key and GCM block mode.
The default value is aes128gcm16-sha256.
