View the table of default routers learned from router advertisement messages.
A maximum of four routers are visible in the default routers list.
This procedure does not apply to VSP 8600 Series.
- In the navigation tree, expand the folders.
- Click IPv6.
- Click the Default Routers tab.
Default Routers field descriptions
Use the data in the following table to use the Default Routers tab.
| Name | Description |
| Address | Specifies the learned router address for an IPv6 default routers entry. |
| IfIndex | Specifies the interface number for an IPv6 default routers entry. |
| Lifetime | Specifies the remaining router lifetime. |
| Active | Specifies if the default router is active for an IPv6 default routers entry. |
