Perform this procedure to show information about the IPv6 active RP for all the running multicast groups on the switch.
- In the navigation pane, expand the following folders: .
- Click IPv6 PIM.
- Click the Active RP tab.
Active RP field descriptions
Use the data in the following table to use the Active RP tab.
| Name | Description |
| GroupAddress | Shows the IPv6 address of the multicast group. |
| Address | Shows the IPv6 address of the RP router. This address can be one of the local PIM-SM enabled interfaces or any reachable global IPv6 address configured using the static-rp CLI command. Note:
                             IPv6 link local address is always used as the PIM interface address. |
| Priority | Shows the priority of the RP. |
