This section provides CLI procedures for Unicast Reverse Path Forwarding configuration.
To configure Unicast Reverse Path Forwarding on a port or VLAN, you are required to enable the urpf-mode boot flag. If you try to configure uRPF on an interface, that is, enable or change the urpf operating mode with the urpf-mode boot flag disabled, a consistency check error message is displayed: Unicast Reverse Path Forwarding configuration is not supported when urpf-mode boot flag is disabled.
Use the following procedure to enable the urpf-mode boot flag. By default, urpf-mode is disabled.
    enable
    configure terminal
  2. Enable the urpf-mode boot flag:
    boot config flags urpf-mode
  3. When you get the following prompt to reboot the switch, enter y to reboot.
    The new setting requires a reboot to take effect!
    The configuration will be saved and rebooted.
    Are you sure you want to re-boot the switch (y/n)?
    If you enter n, the following message is displayed: Warning: Please save the configuration and reboot the switch for this configuration to take effect.
  4. Check the status of the urpf-mode boot flag:
    show boot config flags
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# boot config flags urpf-mode
Are you sure you want to re-boot the switch (y/n)? y
View the status of the urpf-boot flag:
Flag support can vary across hardware models.
Switch:1#show boot config flags
flags advanced-feature-bandwidth-reservation low
flags block-snmp false
flags debug-config false
flags debugmode false
flags dvr-leaf-mode false
flags enhancedsecure-mode false
flags factorydefaults false
flags flow-control-mode true
flags ftpd true
flags ha-cpu true
flags hsecure false
flags ipv6-egress-filter true
flags ipv6-mode false
flags linerate-directed-broadcast false
flags logging true
flags nni-mstp false
flags reboot true
flags rlogind false
flags savetostandby true
flags spanning-tree-mode mstp
flags spbm-config-mode true
flags sshd true
flags syslog-rfc5424-format true
flags telnetd true
flags tftpd true
flags trace-logging false
flags urpf-mode true
flags verify-config true
flags vrf-scaling true
flags vxlan-gw-full-interworking-mode false
Use the following procedure to view the status of the uRPF configuration on a port.
  • You must enable the urpf-mode boot flag.
    When you try to configure uRPF on an interface, that is, enable or change the urpf operating mode with the urpf-mode boot flag disabled, a consistency check error message is displayed: Unicast Reverse Path Forwarding configuration is not supported when urpf-mode boot flag is disabled.
  • You must log on to the GigabitEthernet Interface Configuration mode in CLI.
  • You must configure unicast reverse path forwarding on a port.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
  2. Verify the configuration on the port:
    For IPv4, enter: show ip interface gigabitethernet
    For IPv6, enter: show ipv6 interface gigabitethernet
Example for IPv4:
Switch:1> enable
Switch:1(config)# interface GigabitEthernet 1/10
Switch:1(config-if)# show ip interface gigabitethernet
                                         Brouter Port Ip
PORT VRF   IP_ADDRESS    NET_MASK      BROADCAST REASM   ADVERTISE DIRECT  RPC     RPCMODE
NUM  NAME                                        MAXSIZE WHEN_DOWN BCAST
1/1  Glob~ 192.0.2.3     255.255.255.0 ones      1500    disable   disable disable exist-only
1/10 spbo~ 198.51.100.4  255.255.255.0 ones      1500    disable   disable disable exist-only
PORT  VRF
NUM   NAME
1/1   GlobalRouter
1/10  spboip
Example for IPv6:
Switch:1> enable
Switch:1(config)# interface GigabitEthernet 4/16
Switch:1(config-if)#show ipv6 interface gigabitethernet
                                             Port Ipv6 Interface
IFINDX BROUTER PHYSICAL          ADMIN   OPER  TYPE  MTU  HOP REACHABLE   RETRANSMIT  MCAST    IPSEC    RPC      RPCMODE
INDX           ADDRESS           STATE   STATE            LMT TIME        TIME        STATUS
192    4/16    e4:5d:52:3c:65:02 enable  down  ETHER 1500 2   30000       1000        disable  disable  disable  existonly
                               Port Ipv6 Address
IPV6 ADDRESS                            BROUTER      TYPE    ORIGIN    STATUS
2001:db8:0:0:0:0:0:ffff/64                   4/16          UNICAST MANUAL    INACCESSIBLE INF      INF
2001:db8:0:0:e65d:52ff:fe3c:6502/64          4/16          UNICAST LINKLAYER INACCESSIBLE INF      INF
1 out of 5 Total Num of Interface Entries displayed.
2 out of 10 Total Num of Address Entries displayed.
Use the following procedure to view the status of the uRPF configuration on a VLAN.
  • You must log on to the VLAN Interface Configuration mode in CLI.
    Important
    Important
    You must assign a valid IP address to the selected port.
  • You must configure unicast reverse path forwarding on a VLAN.
  1. Enter VLAN Interface Configuration mode:
    enable
    configure terminal
    interface vlan <1–4059>
  2. Verify the configuration on the VLAN:
    For IPv4, enter: show interfaces vlan ip
    For IPv6, enter: show ipv6 interface vlan
Example for IPv4:
Switch:1> enable
Switch:1(config)# interface vlan 2
Switch:1(config-if)# show interfaces vlan ip
                                                   Vlan Ip
VLAN VRF    IP            NET              BCASTADDR REASM   ADVERTISE DIRECTED  RPC     RPCMODE     RMON
ID   NAME   ADDRESS       MASK             FORMAT    MAXSIZE WHEN_DOWN BROADCAST
1050 Globa~ 192.0.2.9     255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1102 Globa~ 198.51.100.1  255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1133 iir3   192.0.2.10    255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1500 spboip 192.0.2.11    255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
1590 spboip 198.51.100.2  255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
4057 Globa~ 192.0.2.12    255.255.255.0    ones      1500    disable   disable   disable exist-only  disable
All 16 out of 16 Total Num of Vlan Ip Entries displayed
VLAN VRF
ID   NAME
1050 GlobalRouter
1102 GlobalRouter
1133 iir3
1500 spboip
1590 spboip
4057 GlobalRouter
Example for IPv6:
Switch:1> enable
Switch:1(config-if)# show ipv6 interface vlan
                                             Vlan Ipv6 Interface
IFINDX VLAN PHYSICAL          ADMIN   OPER  TYPE  MTU  HOP REACHABLE   RETRANSMIT  MCAST    IPSEC    RPC      RPCMODE
3170   1122 2c:f4:c5:dc:b4:89 enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
3174   1126 2c:f4:c5:dc:b4:8b enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
3185   1137 2c:f4:c5:dc:b4:90 enable  up    ETHER 1500 64  30000       1000        disable  disable  disable  existonly
                               Vlan Ipv6 Address
IPV6 ADDRESS                            VLAN-ID      TYPE    ORIGIN    STATUS
2001:db8:0:0:0:0:0:1                      V-1122       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b489          V-1122       UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1                      V-1126       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b48b          V-1126       UNICAST LINKLAYER PREFERRED
2001:db8:0:0:0:0:0:1                      V-1137       UNICAST MANUAL    PREFERRED
2001:db8:0:0:2ef4:c5ff:fedc:b490          V-1137       UNICAST LINKLAYER PREFERRED
3 out of 4 Total Num of Interface Entries displayed.
6 out of 7 Total Num of Address Entries displayed.
