Use this task to view Management Instance statistics.
show mgmt statistics [clip | oob | vlan]
This step does not apply to VSP 8600 Series.
show mgmt ip icmp-statistics
OR
show mgmt ipv6 icmp-statistics
show mgmt ip ip-statistics
OR
show mgmt ipv6 ip-statistics
show mgmt ip tcp-connections
OR
show mgmt ipv6 tcp-connections
show mgmt ip tcp-statistics
OR
show mgmt ipv6 tcp-statistics
show mgmt ip udp-endpoints
OR
show mgmt ipv6 udp-endpoints
show mgmt ip udp-statistics
OR
show mgmt ipv6 udp-statistics
enable
clear mgmt statistics
Switch:1>show mgmt statistics
                                                 Mgmt Interface Stats Information
INST   DESCR       RX-PKTS             RX-ERROR            RX-DROP             TX-PKTS             TX-ERROR            TX-DROP
1      Mgmt-oob1   111667              0                   0                   21412               0                   0
1 out of 1 Total Num of mgmt interfaces displayed
Switch:1>show mgmt ip icmp-statistics
                        Mgmt ICMP Statistics Information
InMsgs           : 44
InErrors         : 0
InCsumErrors     : 0
InDestUnreachs   : 44
InTimeExcds      : 0
InParmProbs      : 0
InSrcQuenchs     : 0
InRedirects      : 0
InEchos          : 0
InEchoReps       : 0
InTimestamps     : 0
InTimestampReps  : 0
InAddrMask       : 0
InAddrMaskReps   : 0
OutMsgs          : 53
OutErrors        : 0
Switch:1>show mgmt ipv6 icmp-statistics
                       Mgmt ICMPv6 Statistics Information
InMsgs                    : 58
InErrors                  : 0
InCsumErrors              : 0
InDestUnreachs            : 0
InTimeExcds               : 0
InParmProbs               : 0
InPktTooBigs              : 0
InRedirects               : 0
InEchos                   : 0
InEchoReps                : 0
InGroupMembQueries        : 0
InGroupMembReductions     : 0
InRouterSolicits          : 0
InRouterAdvertisements    : 55
InNeighborSolicits        : 0
InNeighborAdvertisements  : 3
InMLDv2Reports            : 0
InType134                 : 55
InType136                 : 3
OutMsgs                   : 69
OutErrors                 : 0
OutDestUnreachs           : 0
OutTimeExcds              : 0
OutParmProbs              : 0
OutPktTooBigs             : 0
OutRedirects              : 0
OutEchos                  : 0
OutEchoReps               : 0
OutGroupMembQueries       : 0
OutGroupMembResponses     : 0
OutGroupMembReductions    : 0
OutRouterSolicits         : 0
OutRouterAdvertisements   : 0
OutNeighborSolicits       : 13
OutNeighborAdvertisements : 0
OutMLDv2Reports           : 56
OutType133                : 56
OutType135                : 13
OutType143                : 0
Switch:1>show mgmt ip ip-statistics
                         Mgmt IP Statistics Information
InReceives        : 1231729
InHdrErrors       : 0
InAddrErrors      : 489
InUnknownProtos   : 0
InDiscards        : 0
InDelivers        : 1221886
OutRequests       : 1212585
OutDiscards       : 20
OutNoRoutes       : 0
ForwDatagrams     : 0
ReasmTimeout      : 0
ReasmReqds        : 0
ReasmOKs          : 0
ReasmFails        : 0
FragOKs           : 0
FragFails         : 0
FragCreates       : 0
Switch:1>show mgmt ipv6 ip-statistics
                        Mgmt IPv6 Statistics Information
InReceives        : 226
InHdrErrors       : 0
InAddrErrors      : 0
InUnknownProtos   : 0
InDiscards        : 0
InDelivers        : 62
InTooBigErrors    : 0
InNoRoutes        : 0
InTruncatedPkts   : 0
InMcastPkts       : 224
InOctets          : 20556
InMcastOctets     : 20416
InBcastOctets     : 0
InNoECTPkts       : 226
InECT1Pkts        : 0
InECT0Pkts        : 0
InCEPkts          : 0
OutRequests       : 71
OutDiscards       : 0
OutNoRoutes       : 0
OutForwDatagrams  : 0
OutMcastPkts      : 69
OutOctets         : 5412
OutMcastOctets    : 5272
OutBcastOctets    : 0
ReasmTimeout      : 0
ReasmReqds        : 0
ReasmOKs          : 0
ReasmFails        : 0
FragOKs           : 0
FragFails         : 0
FragCreates       : 0
      Switch:1>show mgmt ip tcp-connections
                                                     Mgmt IP TCP connections
STATE            RECV-Q     SEND-Q     Local Address:Port                            Peer Address:Port
LISTEN           0          5          0.0.0.0:ftp                                   0.0.0.0:*
LISTEN           0          5          0.0.0.0:telnet                                0.0.0.0:*
LISTEN           0          40         0.0.0.0:https                                 0.0.0.0:*
LISTEN           0          1          0.0.0.0:login                                 0.0.0.0:*
ESTAB            0          0          192.0.2.10:https                              198.51.100.1:50694
ESTAB            0          3          192.0.2.10:telnet                             198.51.100.1:58862
ESTAB            0          0          192.0.2.10:https                              198.51.100.1:59774
      Switch:1>show mgmt ipv6 tcp-connections
                                                    Mgmt IPv6 TCP connections
LISTEN           0          5          *:ftp                                         *:*
LISTEN           0          5          *:telnet                                      *:*
LISTEN           0          40         *:https                                       *:*
LISTEN           0          1          *:login                                       *:*
      Switch:1>show mgmt ip tcp-statistics
                Mgmt Combined IPv4/v6 TCP Statistics Information
TcpActiveOpens    : 9571
TcpPassiveOpens   : 9658
TcpAttemptFails   : 17
TcpEstabResets    : 86
TcpInSegs         : 1207867
TcpOutSegs        : 1199088
TcpRetransSegs    : 42
TcpInErrs         : 0
TcpOutRsts        : 89
TcpInCsumErrors   : 0
      Switch:1>show mgmt ipv6 tcp-statistics
TcpActiveOpens    : 9626
TcpPassiveOpens   : 9713
TcpEstabResets    : 86
TcpInSegs         : 1212159
TcpOutSegs        : 1203293
TcpRetransSegs    : 42
TcpInErrs         : 0
TcpOutRsts        : 89
      Switch:1>show mgmt ip udp-endpoints
                                                      Mgmt IP UDP endpoints
UNCONN           0          0          0.0.0.0:bootpc                                0.0.0.0:*
UNCONN           0          0          0.0.0.0:tftp                                  0.0.0.0:*
UNCONN           0          0          192.0.2.10:ntp                                0.0.0.0:*
UNCONN           0          0          0.0.0.0:ntp                                   0.0.0.0:*
UNCONN           0          0          0.0.0.0:snmp                                  0.0.0.0:*
      Switch:1>show mgmt ipv6 udp-endpoints
                                                     Mgmt IPv6 UDP endpoints
UNCONN           0          0          [0:0:0:0:0:0:0:1]:domain                      *:*
UNCONN           0          0          *:tftp                                        *:*
UNCONN           0          0          [fe80:0:0:0:f66e:95ff:fe9f:81]:ntp            *:*
UNCONN           0          0          [fe80:0:0:0:f66e:95ff:fe9f:a5]:ntp            *:*
UNCONN           0          0          [fe80:0:0:0:a8bb:ccff:fedd:ee01]:ntp          *:*
UNCONN           0          0          [fe80:0:0:0:fce7:79ff:fe04:999c]:ntp          *:*
UNCONN           0          0          [fe80:0:0:0:609a:4aff:fe4e:cf04]:ntp          *:*
UNCONN           0          0          [fe80:0:0:0:c482:2aff:fe75:2e66]:ntp          *:*
UNCONN           0          0          [fe80:0:0:0:c80a:73ff:fe00:364e]:ntp          *:*
UNCONN           0          0          [fe80:0:0:0:80cc:e9ff:fec7:b9e2]:ntp          *:*
UNCONN           0          0          [fe80:0:0:0:64da:41ff:fec5:489e]:ntp          *:*
UNCONN           0          0          [fe80:0:0:0:f8d7:d6ff:feda:62bc]:ntp          *:*
UNCONN           0          0          [fe80:0:0:0:f66e:95ff:fe9f:0]:ntp             *:*
UNCONN           0          0          [0:0:0:0:0:0:0:1]:ntp                         *:*
UNCONN           0          0          *:ntp                                         *:*
UNCONN           0          0          *:snmp                                        *:*
      Switch:1>show mgmt ip udp-statistics
                         Mgmt UDP Statistics Information
UdpInDatagrams    : 63622
UdpNoPorts        : 44
UdpInErrors       : 0
UdpOutDatagrams   : 63666
UdpIgnoredMulti   : 0
UdpRcvbufErrors   : 0
UdpSndbufErrors   : 0
UdpInCsumErrors   : 0
      Switch:1>show mgmt ipv6 udp-statistics
                        Mgmt UDP6 Statistics Information
Udp6InDatagrams    : 0
Udp6NoPorts        : 0
Udp6InErrors       : 0
Udp6OutDatagrams   : 0
Udp6IgnoredMulti   : 0
Udp6RcvbufErrors   : 0
Udp6SndbufErrors   : 0
Udp6InCsumErrors   : 0
