Configure individual system-level switch parameters to configure global options for the switch.
Switch:1> enable
Switch:1# configure terminal
Configure the system, or root level, prompt name for the switch:
Switch:1(config)# sys name Floor3Lab2
The following table defines parameters for the sys command.
| Variable | Value |
|  clipId-topology-ip
                   Note:
                     Exception: Only supported on VSP 8600 Series | Configures the topology ip from the available CLIP. WORD<1-256>specifies the Circuitless IP interface id. |
| control tcp-timestamp | Enables or disables TCP Timestamp. |
| force-msg | Adds forced message control pattern. WORD<4–4> Enter force message pattern. |
|  force-topology-ip-flag  Note:
                     Exception: Only supported on VSP 8600 Series | Flags set to force choice of topology flag. enable |
| msg-control | Configures system message control feature. |
| mtu <1522-9600> | Configures Jumbo frame support for the data path. The value can be either 1522, 1950 (default), or 9600 bytes. |
| name WORD<0–255> | Configures the system, or root level, prompt name for the switch. WORD<0–255> is an ASCII string from 0–255 characters (for example, LabSC7 or Closet4). |
| power | Enables power to specified slot(s). |
| security-console | Enables the security console. |
| software | Configures software configuration. |
| priv-exec-password | Enables authentication for the Privileged EXEC CLI command mode. |
