This procedure does not apply to VSP 8600 Series and XA1400 Series.
                    Enable Auto-sense on the port.
                    Associate a VLAN with the I-SID before you configure it as the global data I-SID.
Perform this task to configure Auto-sense data traffic information for ports that are operating in Auto-sense mode.
This option applies to the auto-sense UNI and voice states only, it replaces the onboarding I-SID and places an (untagged) client device into a pre-defined global data I-SID.Procedure
Configuring the Auto-sense data I-SID:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#auto-sense data i-sid 1000
The following table defines parameters for the auto-sense data command.
| Variable | Value |
| i-sid <1-15999999> | Specifies the service instance identifier (I-SID). |
