Use the ingress port-rate limiter to limit the traffic rate accepted by the specified
            ingress port. The system drops or re-marks violating traffic.
                In the Device Physical View tab,
                    select a port.
                In the navigation pane, expand
                    the  folders.
                Click General.
                Click the Interface
                    tab.
                From IngressRateLimit
                    , type the value in Kbps to set the traffic rate limit.
                    The ingress rate limit must be between 1000 and 40000000.
                Click Apply.
