Use this procedure to configure the certificate authority (CA) to use Simple Certificate Enrollment Protocol (SCEP) with a CA server for online certificate provisioning.
Switch:1>enable Switch:1#virtual-service FIGW console FIGW>set certificate ca-trustpoint caExtremeEJBCA ca-url http://192.0.2.9:8080/ejbca/publicweb/apply/scep/test/pkiclient.exe FIGW>set certificate ca-trustpoint caExtremeEJBCA caname subca5 FIGW>set certificate ca-trustpoint caExtremeEJBCA get-method post
The following table defines parameters for the set certificate ca-trustpoint command.
| Variable | Value |
| <ca-label> | Specifies the name of the certificate authority (CA). The name can use alphanumeric characters and is case-sensitive. The maximum length is 45 characters. |
| ca-url <ca-url> | Specifies the trusted CA URL. |
| caname <caname> | Specifies the name of the owner of the device or user. |
| get-method <post | get> | Specifies the HTTP request style. You can use post for EJBCA or get for Win2012 CA. The default value is post. |
The following table defines parameters for the certificate ca command.
| Variable | Value |
| <ca-trustpoint> | Specifies the name of the certificate authority. The name can be alphanumeric and is case-sensitive. The maximum length is 45 characters. |
| <subject-label> | Specifies the subject identity. |
The following table defines parameters for the certificate get command.
| Variable | Value |
| cacert-from <A.B.C.D> <user> <file-path> | Specifies where to obtain the CA certificate. Specify the IP address, username, and remote file path. |
| crl-from <A.B.C.D> <user> <file-path> <cacert-filename> | Specifies where to obtain the Certificate Revocation List. Specify the IP address, username, remote file path, and the CA certificate file to verify the CRL. |
| signedcert-from <A.B.C.D> <user> <file-path> <subject-label> | Specifies where to obtain the subject certificate. Specify the IP address, username, remote file path, and subject label. |
