View the administrative status for modules in the chassis.
This command is not available for hardware platforms with fixed configurations. It is only available for platforms where the user can install modules in slots.
- In the Device Physical View tab, select a module slot.
- Click Card.
- Click the Card tab.
Card field descriptions
Use the data in the following table to use the Card tab.
| Name | Description |
| CardType | Displays the model number of the module. |
| CardDescription | Shows a description of the installed module. |
| SerialNum | Shows the serial number for the installed module. |
| PartNumber | Shows the part number. |
| CardAssemblyDate | Shows the date the module was assembled. |
| CardHWConfig | Shows the hardware revision. |
| AdminStatus | Changes the administrative status for the module. |
| OperStatus | Shows the operational status for the module. |
| PowerManagementPriority | Specifies the slot priority for power management as either high or low. |
