Configure the global action to mirror packets that match an access control list (ACL).
- The ACL exists.
Switch:1> enable
Switch:1# configure terminal
Configure the global action for an ACL:
Switch:1(config)# filter acl set 200 global-action monitor-dst-mlt 20
The following table defines parameters for the filter acl set command.
| Variable | Value |
| <1-2048> | Specifies an ACL ID from 1–2048. |
| default-action <deny|permit> | Specifies the global action to take for packets that do not match an ACL. |
| global-action {monitor-dst-mlt PT_MLT<1–512>|monitor-dst-ports {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} | Specifies the global action to take for matching ACLs:
