The following table and sections list the RFCs that the switch supports.
| Request for comment | Description |
| draft-grant-tacacs-02.txt | TACACS+ Protocol |
| RFC 768 | UDP Protocol |
| RFC 783 | Trivial File Transfer Protocol (TFTP) |
| RFC 791 | Internet Protocol (IP) |
| RFC 792 | Internet Control Message Protocol (ICMP) |
| RFC 793 | Transmission Control Protocol (TCP) |
| RFC 815 | IP Datagram Reassembly Algorithm |
| RFC 826 | Address Resolution Protocol (ARP) |
| RFC 854 | Telnet protocol |
| RFC 894 | A standard for the Transmission of IP Datagrams over Ethernet Networks |
| RFC 896 | Congestion control in IP/TCP internetworks |
| RFC 906 | Bootstrap loading using TFTP |
| RFC 950 | Internet Standard Subnetting Procedure |
| RFC 951 | BootP |
| RFC 959, RFC 1350, and RFC 2428 | FTP and TFTP client and server |
| RFC 1027 | Using ARP to implement transparent subnet gateways/Nortel Subnet based VLAN |
| RFC 1058 | RIPv1 Protocol |
| RFC 1112 | Host Extensions for IP Multicasting (IGMPv1) |
| RFC 1122 | Requirements for Internet Hosts |
| RFC 1195 | Use of OSI IS-IS for Routing in TCP/IP and Dual Environments |
| RFC 1042 | Encapsulating the Internet Protocol (IP) datagrams and Address Resolution Protocol (ARP) Note:
                   Applicable for 802.3 networks only |
| RFC 1253 | OSPF MIB |
| RFC 1256 | ICMP Router Discovery |
| RFC 1258 Note:
                   Exception: rlogin is only supported on VSP 8600 Series. | IPv6 Rlogin server |
| RFC 1305 | Network Time Protocol v3 Specification, Implementation and Analysis |
| RFC 1323 | TCP Timestamp (The switch is only compliant if the TCP timestamp is enabled.) |
| RFC 1340 | Assigned Numbers |
| RFC 1519 | Classless Inter-Domain Routing (CIDR): an Address Assignment and Aggregation Strategy |
| RFC 1541 | Dynamic Host Configuration Protocol |
| RFC 1542 | Clarifications and Extensions for the Bootstrap Protocol |
| RFC 1587 | The OSPF NSSA Option |
| RFC 1591 | DNS Client |
| RFC 1723 | RIP v2 — Carrying Additional Information |
| RFC 1812 | Router requirements |
| RFC 1866 | Hypertext Markup Language version 2 (HTMLv2) protocol |
| RFC 1981 | Path MTU discovery |
| RFC 2068 | Hypertext Transfer Protocol |
| RFC 2080 | RIP |
| RFC 2131 | Dynamic Host Control Protocol (DHCP) |
| RFC 2132 | DHCP Options and BOOTP Vendor Extensions |
| RFC 2138 | RADIUS Authentication |
| RFC 2139 | RADIUS Accounting |
| RFC 2178 | OSPF MD5 cryptographic authentication / OSPFv2 |
| RFC 2233 | The Interfaces Group MIB using SMIv2 |
| RFC 2236 | IGMPv2 Snooping |
| RFC 2358 | Definitions of Managed Objects for the Ethernet-like Interface Types |
| RFC 2284 | PPP Extensible Authentication Protocol |
| RFC 2328 | OSPFv2 |
| RFC 2338 | VRRP: Virtual Redundancy Router Protocol |
| RFC 2362 | PIM-SM |
| RFC 2407 | IP Security Domain Interpretation of Internet Security Association and Key Management Protocol (ISAKMP) |
| RFC 2408 | Internet Security Associations and Key Management Protocol (ISAKMP) |
| RFC 2453 | RIPv2 Protocol |
| RFC 2460 | IPv6 base stack |
| RFC 2462 | IPv6 Stateless Address Autoconfiguration |
| RFC 2463 | Internet Control Message Protocol (ICMPv6) for the Internet Protocol Version 6 (IPv6) Specification |
| RFC 2464 | Transmission of IPv6 packets over Ethernet networks |
| RFC 2474 | Definition of the Differentiated Services Field (DS Field) in the IPv4 and IPv6 Headers |
| RFC 2475 | An Architecture for Differentiated Services |
| RFC 2545 | Use of BGP-4 multi-protocol extensions for IPv6 inter-domain routing |
| RFC 2548 | Microsoft vendor specific RADIUS attributes |
| RFC 2579 | Textual Conventions for SMI v2 |
| RFC 2580 | Conformance Statements for SMI v2 |
| RFC 2616 | Hypertext Transfer Protocol 1.1 |
| RFC 2710 | Multicast Listener Discovery (MLD) for IPv6 |
| RFC 2716 | PPP EAP Transport Level Security (TLS) Authentication Protocol |
| RFC 2737 | Entity MIB (Version 2) |
| RFC 2819 | RMON |
| RFC 2865 | RADIUS |
| RFC 2874 | DNS Extensions for IPv6 |
| RFC 2918 | Route Refresh Capability for BGP-4 |
| RFC 2992 | Analysis of an Equal-Cost Multi-Path Algorithm |
| RFC 3046 | DHCP Option 82 |
| RFC 3162 | IPv6 RADIUS client |
| RFC 3246 | An Expedited Forwarding PHB (Per-Hop Behavior) |
| RFC 3315 | IPv6 DHCP Relay |
| RFC 3376 | IGMPv3 |
| RFC 3411 and RFC 2418 | SNMP over IPv6 networks |
| RFC 3417 | Transport Mappings for SNMP |
| RFC 3484 | Default Address Selection for IPv6 |
| RFC 3513 | Internet Protocol Version 6 (IPv6) Addressing Architecture |
| RFC 3569 | An overview of Source-Specific Multicast (SSM) |
| RFC 3579 | RADIUS Support For Extensible Authentication Protocol (EAP) |
| RFC 3580 | IEEE 802.1X Remote Authentication Dial In User Service |
| RFC 3587 | IPv6 Global Unicast Address Format |
| RFC 3596 | DNS Extensions for IPv6 |
| RFC 3621 | Power Ethernet MIB |
| RFC 3748 | Extensible Authentication Protocol |
| RFC 3810 | Multicast Listener Discovery Version 2 (MLDv2) for IPv6 |
| RFC 3825 | Dynamic Host Configuration Protocol Option for Coordinate-based Location Configuration Information |
| RFC 3879 | Deprecating Site Local Addresses |
| RFC 3986 | Uniform Resource Identifiers (URI) |
| RFC 4007 | IPv6 Scoped Address Architecture |
| RFC 4022 | MIB for TCP |
| RFC 4113 | MIB for UDP |
| RFC 4133 | Entity MIB (version 3) |
| RFC 4193 | Unique Local IPv6 Unicast Address |
| RFC 4213 | IPv6 configured tunnel |
| RFC 4250–RFC 4256 | SSH server and client support |
| RFC 4291 | IPv6 Addressing Architecture |
| RFC 4293 | MIB for IP |
| RFC 4301 | Security Architecture for IPv6 |
| RFC 4302 | IP Authentication Header (AH) |
| RFC 4303 | IP Encapsulated Security Payload (ESP) |
| RFC 4305 | Cryptographic algorithm implementation requirements for ESP and AH |
| RFC 4308 | Cryptographic suites for Internet Protocol Security (IPsec) |
| RFC 4443 | ICMP for IPv6 |
| RFC 4541 | Internet Group Management Protocol (IGMP) and Multicast Listener Discovery (MLD) Snooping |
| RFC 4552 | OSPFv3 Authentication and confidentiality for OSPFv3 |
| RFC 4601 | Protocol Independent Multicast - Sparse Mode (PIM-SM) |
| RFC 4604 | Internet Group Management Protocol Version 3 (IGMPv3) and Multicast Listener Discovery Protocol Version 2 (MLDv2) for Source-Specific Multicast |
| RFC 4607 | Source-Specific Multicast (SSM) |
| RFC 4649 | Dynamic Host Configuration Protocol for IPv6 (DHCPv6) Relay Agent Remote-ID Option |
| RFC 4675 | Egress VLAN |
| RFC 4750 | OSPFv2 MIB |
| RFC 4760 | Multiprotocol Extensions for BGP-4 |
| RFC 4835 | Cryptographic algorithm implementation for ESP and AH |
| RFC 4861 | IPv6 Neighbor discovery |
| RFC 4862 | IPv6 stateless address autoconfiguration |
| RFC 4893 | BGP Support for Four-octet AS Number Space |
| RFC 5095 | Deprecation of Type 0 Routing headers in IPv6 |
| RFC 5176 | Dynamic Authorization Extensions to Remote Authentication Dial In User Service (RADIUS) |
| RFC 5187 | OSPFv3 Graceful Restart (helper-mode only) |
| RFC 5242 | The Syslog Protocol |
| RFC 5321 | Simple Mail Transfer Protocol |
| RFC 5340 | OSPF for IPv6 |
| RFC 5746 | Secure SSL Renegotiation |
| RFC 5798 | Virtual Router Redundancy Protocol (VRRP) Version 3 for IPv4 and IPv6 |
| RFC 5905 | Network Time Protocol Version 4: Protocol and Algorithms Specification |
| RFC 5997 | Use of Status-Server Packets in the Remote Authentication Dial In User Service (RADIUS) Protocol |
| RFC 6105 | IPv6 Router Advertisement Guard |
| RFC 6329 | IS-IS Extensions supporting Shortest Path Bridging |
| RFC 7047 | The Open vSwitch Database Management Protocol |
| RFC 7348 | Virtual Extensible LAN (VXLAN) |
| RFC 7610 | DHCPv6 Shield |
