Use this procedure to configure the maximum EAP clients allowed on the port at one time.
Configure the maximum EAP clients allowed on the port at one time.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/1 Switch:1(config)#eapol multihost eap-mac-max 10
The following table defines parameters for the eapol multihost eap-mac-max command.
| Variable | Value |
| <0–32> | Specifies the maximum EAP clients allowed on the port at one time. The default is 2. |
