Enable VRRP global variables to enable the VRRP function.
- In the navigation pane, expand the following folders: .
- Click VRRP.
- Click the Globals tab.
- Configure the required features.
- Click Apply.
Globals field descriptions
Use the data in the following table to use the Globals tab.
| Name | Description |
| NotificationCntl | Indicates whether the VRRP-enabled router generates SNMP traps
for events.
 The default is enabled. |
| PingVirtualAddrEnable | Configures whether this device responds to pings directed to a virtual router IP address. The default is enabled. |
