Configure ACE actions
DEMO FEATURE - Policy Based Routing (Redirect Next Hop) per VRF is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information, see VOSS Feature Support Matrix.
Configure ACE actions to determine the process that occurs after a packet matches an ACE.
- Create ACE and ACL.
Configure ACE actions:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#filter acl ace action 1 47 permit redirect-next-hop 192.0.2.5 unreachable deny count
Display the configuration using the show filter ace action command:
Switch:1(config)#show filter acl action
                           Ace Action Table (Part I)
Acl  Ace  AceName                  Admin   Oper    Mode   Mlt Remark  Remark
Id   Id                            State   State           Id DSCP    Dot1p
1    47   ace47                    Disable Down    permit 0   disable disable
                           Ace Action Table (Part II)
Acl  Ace  Redirect                      Vrf                     Unreach Police  Internal
Id   Id   Next-Hop                      name                    -able           Qos
1    47   2.0.0.0                       GlobalRouter            deny    0       0
                          Ace Action Table (Part III)
Acl  Ace  Ipfix   Count   Log     CopyTo  Monitor  Monitor   Monitor
Id   Id                           Pcap    Dst-Mlt  Dst-Vlan  Dst-Port
1    47   disable enable  disable disable 1        0
                           Ace Action Table (Part IV)
Acl  Ace  Monitor           Dscp     Ttl      Monitor    Isid   QoS Remove-Tag
Id   Id   Dst-Ip                              Isid       Offset
1    47   0.0.0.0           ----     ----     ---        ---    ---
Displayed 1 of 1 Entries
                                                  Display the configuration using the show filter acl config command:
Switch:1(config)#show filter acl config
                          Filter ACL-ACE Configuration
filter acl 1 type inPort name "ACL-1"
filter acl set 1 policer svc-rate 100 peak-rate 200
filter acl port 1 1/1
filter acl ace 1 1
filter acl ace action 1 1 permit count
filter acl ace ethernet 1 1 src-mac eq aa:bb:cc:dd:ee:ff
filter acl ace policer 1 1 svc-rate 300 peak-rate 400
filter acl ace 1 1 enable
filter acl ace 1 2
filter acl ace action 1 2 permit count
filter acl ace ethernet 1 2 dst-mac eq ff:ff:ff:ff:ff:ff
filter acl ace policer 1 2 svc-rate 500 peak-rate 600
filter acl ace 1 2 enable
filter acl 3 type inPort name "ACL-3"
filter acl set 3 policer svc-rate 800 peak-rate 1000
filter acl port 3 1/7-1/8
filter acl ace 3 2
filter acl ace action 3 2 permit count
filter acl ace ethernet 3 2 dst-mac eq 00:00:00:00:00:33
filter acl ace policer 3 2 svc-rate 1000 peak-rate 4000
filter acl ace 3 2 enable
                                                  Display the configuration using the show filter acl ace command:
Switch:1(config)#show filter acl ace
1    1    ACE-1                    Enable  Up      permit 0   disable disable
1    2    ACE-2                    Enable  Up      permit 0   disable disable
3    2    ACE-2                    Enable  Up      permit 0   disable disable
4    4    ACE-4                    Disable Down    permit 0   disable disable
6    10   ACE-10                   Disable Down    permit 0   disable disable
15   15   ACL15                    Enable  Up      permit 0   phbaf23 disable
1    1    0.0.0.0             GlobalRouter            deny    0       0
1    2    0.0.0.0             GlobalRouter            deny    0       0
3    2    0.0.0.0             GlobalRouter            deny    0       0
4    4    0.0.0.0             GlobalRouter            deny    0       0
6    10   0:0:0:0:0:0:0:0     GlobalRouter            deny    0       0
15   15   0:0:0:0:0:0:0:0     GlobalRouter            deny    0       0
1    1    disable enable  disable 0        0
1    2    disable enable  disable 0        0
3    2    disable enable  disable 0        0
4    4    disable disable disable 0        0
6    10   disable disable disable 0        0
15   15   disable enable  disable 0        0
1    1    0.0.0.0           ----     ----     ---        ---    ---
1    2    0.0.0.0           ----     ----     ---        ---    ---
3    2    0.0.0.0           ----     ----     ---        ---    ---
4    4    0.0.0.0           ----     ----     ---        ---    ---
6    10   0.0.0.0           ----     ----     ---        ---    ---
15   15   0.0.0.0           ----     ----     ---        ---    ---
Displayed 3 of 3 Entries
                                 ACE Arp Table
AclId  AceId  Operation
1      1
1      2
3      2
4      4
6      10
15     15
Displayed 3 of 3 entries
                          ACE Ethernet Table (Part I)
Acl  Ace  Operator/              Operator/              Operator/
Id   Id   SourceMac              DestMac                PortList
1    1    eq aa:bb:cc:dd:ee:ff
1    2    eq ff:ff:ff:ff:ff:ff
3    2    eq 00:00:00:00:00:33
4    4
6    10
15   15
                          ACE Ethernet Table (Part II)
Id   Id   EtherType              VlanId                 VlanTagPrio
1    1
1    2
3    2
4    4
6    10
15   15                          eq 10
                             ACE Ip Table (Part I)
Acl  Ace  Operator/          SourceIp        Operator/          DestIp
Id   Id   SourceIp           mask            DestIp             mask
1    1
1    2
3    2
4    4
6    10
15   15
                             ACE Ip Table (Part II)
Acl  Ace  Ip     Operator/            Operator/            Operator/
Id   Id   Option IpFragFlag           IpProtoType          Dscp
1    1
1    2
3    2
4    4
6    10
15   15
                            ACE Ipv6 Table (Part I)
Acl  Ace  Operator/                     SrcIpv6
Id   Id   SrcIpv6                       mask
1    1
1    2
3    2
4    4
6    10
15   15
                            ACE Ipv6 Table (Part II)
Acl  Ace  Operator/                     DstIpv6
Id   Id   DstIpv6                       mask
1    1
1    2
3    2
4    4
6    10
15   15
                           ACE Ipv6 Table (Part III)
Id   Id   NxtHdr                        Traffic-Cls
1    1
1    2
3    2
4    4
6    10
15   15
                               ACE Policer Table
Acl   Ace   Service-rate Peak-rate
Id    Id
1     1     300          400
1     2     500          600
3     2     1000         4000
4     4
6     10
15    15
                          ACE Protocol Table (Part I)
Id   Id   SrcPort                DstPort
1    1
1    2
3    2
4    4     eq aa:bb:cc:dd:ee:ff
6    10    eq ff:ff:ff:ff:ff:ff
15   15    eq 00:00:00:00:00:33
ACE Protocol Table (Part II)
Id   Id   TcpFlags               IcmpMsgType
1    1
1    2
3    2
4    4
6    10
15   15
                         ACE Protocol Table (Part III)
Acl  Ace  Operator/
Id   Id   Routing-Type
1    1
1    2
3    2
4    4
6    10
15   15
Use the data in the following table to use the filter acl ace action command.
| Variable | Value |
| <acl-id> | Specifies the ACL ID. Use the CLI Help to see the available range for the switch. |
| <ace-id> | Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch. |
| count | Enables the ability to count matching packets. Use this parameter with either a security or QoS ACE. The default is disabled. |
| <deny|permit> | Configures the action mode for security ACEs. Note:
                                     For each Security ACE, you must define one or more actions as well as the associated action mode (permit or deny). Otherwise, the security ACE cannot be enabled. There is no default configuration for Security ACEs. With QoS ACEs, the action mode is not configurable. QoS ACEs are always set to action mode permit. |
| monitor-isid-offset <1–1000> | Specifies the offset ID which will be mapped to the actual monitor I-SID where packets are mirrored. Monitor I-SID = base monitor I-SID + offset ID. The base monitor I-SID is 16776000. |
| internal-qos <0–7> | This variable is a QoS action.The default value is 1. Note:
                                 This does not apply to IPv6 filtering. |
| monitor-dst-ports {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} | Configures mirroring to a destination port or ports. This action is a security action. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| monitor-dst-mlt <1–512> | Configures mirroring to a destination MLT in the range of 1 to 512. |
| redirect-next-hop WORD <1–45> | Specifies the nexthop IPv4 or IPv6 address for redirect node. This action is a security action. Note:
                                 redirect-next-hop is available for demonstration purposes on some products. For more information, see VOSS Feature Support Matrix. |
| unreachable <permit|deny> | Denies or permits packet dropping when the next hop for the packet is unreachable. The default value is deny. This action is a security action. Note:
                                 unreachable is available for demonstration purposes on some products. For more information, see .VOSS Feature Support Matrix |
| vrf WORD<1–16> | Specifies the direct next hop VRF name. The name must be in the ranger of 1 to 16 characters. Note:
                                 vrf is available for demonstration purposes on some products. For more information, see VOSS Feature Support Matrix. |
| remark-dscp <phbcs0 | phbcs1 | phbaf11 | phbaf12 | phbaf13 | phbcs2 | phbaf21 | phbaf22 | phbaf23 | phbcs3 | phbaf31 | phbaf32 | phbaf33 | phbcs4 | phbaf41 | phbaf42 | phbaf43 | phbcs5 | phbcs6 | phbef | phbcs7> | Specifies the new Per-Hop Behavior (PHB) for matching packets: phbcs0, phbcs1, phbaf11, phbaf12, phbaf13, phbcs2, phbaf21, phbaf22, phbaf23, phbcs3, phbaf31, phbaf32, phbaf33, phbcs4, phbaf41, phbaf42, phbaf43, phbcs5, phbef, phbcs6, phbcs7. This action is a QoS action. Note:
                                 This action applies to IPv6 filtering. |
| remark-dot1p <0–7> | Specifies the new 802.1 priority bit for matching packets: zero, one, two, three, four, five, six, or seven. This action is a QoS action. Note:
