View the IPv4 address bindings that IPSG allows.
- Select Source Guard.
- Select the IP Source Guard-addresses tab.
IP Source Guard-addresses field descriptions
Use the data in the following table to use the IP Source Guard-addresses tab.
| Field | Description |
| Port | Indicates the port on which IPSG is configured. |
| Type | Indicates the address type. |
| Address | Indicates the IPv4 address that is allowed by IPSG on the port. |
| Source | Indicates the source of the IPv4 address, which is DHCP Snooping. |
