By default, a DvR Controller injects default routes into the DvR domain and all the Leaf nodes in that domain learn these routes with the next hop as the Controller that advertised them.
You can however disable default route injection for the GRT or a specific VRF on a Controller, to override this behavior.
enable
configure terminal
Optional: router vrf WORD<1-16>
On the GRT:
dvr controller inject-default-route-disable
The default or the no operator enables injection of default routes for the GRT into the domain.
On a VRF instance:
dvr inject-default-route-disable
The default or the no operator enables injection of default routes for a specific VRF into the domain.
On the GRT:
show dvr
On a VRF instance:
show dvr l3vsn
Disable injection of default routes for the GRT on a Controller.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#dvr controller inject-default-route-disable
Switch:1(config)#show dvr
                    DVR Summary Info
Domain ID                      : 5
Domain ISID                    : 16678219
Backbone ISID                  : 16678216
Role                           : Controller
My SYS ID                      : 00:bb:00:00:81:21
Operational State              : Up
GW MAC                         : 00:00:5e:00:01:25
InjectDefaultRouteDisable(GRT) : Enabled
                                                  Disable injection of default routes for a specific VRF on a Controller.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#router vrf vrf3 Switch:1(router-vrf)#dvr inject-default-route-disable
Switch:1(router-vrf)#show dvr l3vsn
                                        DVR L3VSN
VRF ID            L3VSN ISID        VRF NAME             INJECT-DEFAULT-ROUTE-DISABLE
1                 50                green                Disabled
7                 1000003           vrf3                 Enabled
2 out of 2 Total Num of DVR L3VSN displayed
