Perform this procedure to view MACsec status.
MACsec status
MACsec encryption status
MACsec encryption cipher suite, if supported on your hardware platform
The associated Connectivity Association (CA) name
If you do not specify a port number, the information on all MACsec capable interfaces is displayed.
enable
show macsec status {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}
show macsec
The switch does not support replay protect.
View MACsec status:
Switch:1#show macsec status
                                                    MACSEC Port Status
         MACSEC     Encryption  Replay      Replay       Encryption       Cipher     CA       MKA-Profile      MKA Connect
PortId   Status     Status     Protect     Protect W'dow   Offset         Suite      Name     Name             Status
1/13     disabled   disabled    disabled   --              none            AES-128   NIL	  --                --
1/14     disabled   disabled    disabled   --              none	     AES-128   NIL         --                --
1/15     enabled    disabled    enabled    50              ipv4Offset(30)  AES-256   mkanka   extreme           pending
      View MACsec status on port 1/13:
Switch:1#show macsec status 1/13
                                                    MACSEC Port Status
1/13     enabled	disabled    enabled     50          ipv4Offset(30)  AES-256   mkanka   extreme          pending
      Display all MACsec information:
                     MACSEC Connectivity Associations Info
  Connectivity                Connectivity                 AN_Mode /      Port
Association Name          Association Key Hash            TxKeyParity     Members
mkanakexit`                d4433e901bae92d0cc472706f66cfc18      4AN / odd
All 1 out of 1 Total Num of Macsec connectivity associates displayed
                                                    MACSEC Port Status
--More-- (q = quit)
