Use this procedure to protect additional host names with a single certificate.
The switch supports 100 subject alternative names.
Configure a subject alternative name subject name 822:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#certificate subject-alternative-name subject-name 822 dns 822.extremenetworks.com Switch:1(config)#certificate subject-alternative-name subject-name 822 e-mail name@company.com Switch:1(config)#certificate subject-alternative-name subject-name 822 ip 192.0.2.22
View the configuration:
Switch:1>show certificate subject-alternative-name
                                   SAN Table
TYPE     NAME                       SUBJECT
E-MAIL   name@company.com           822
DNS      822.extremenetworks.com    822
IP       192.0.2.22                 822
            Configure a subject alternative name with the default subject name:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#certificate subject-alternative-name dns name@extrnetwk.com Switch:1(config)#certificate subject-alternative-name e-mail j.smith@extremenetworks.com Switch:1(config)#certificate subject-alternative-name ip 192.0.2.23
                                        SAN Table
TYPE     NAME                                  SUBJECT
E-MAIL   j.smith@extremenetworks.com           Global
DNS      name@extrnetwk.com                    Global
IP       192.0.2.23                            Global
The following table defines parameters for the certificate subject-alternative-name command.
| Variable | Value |
| dns WORD<1-255> | Specifies the DNS subject alternative name. |
| e-mail WORD<1-255> | Specifies the e-mail subject alternative name. |
| ip WORD<1-255> | Specifies the IP subject alternative name. |
| subject-name
                                WORD<1-45> Note:
                                     Exception: Not supported on VSP 8600 Series. | Specifies the Subject Identity Label to be used in local digital certificate request. You can configure up to 10 subject DN identities. If the subject-name is not specified, the default subject name is Global. |
