Configure a prefix list to allow or deny specific route updates. A prefix list policy specifies route prefixes to match. After a match occurs, the system uses the route.
The prefix list contains a set of contiguous or non-contiguous routes. Reference prefix lists by name from within a routing policy.
- Change the VRF instance as required to configure a prefix list on a specific VRF instance.
- In the navigation pane, expand the following folders: .
- Click Policy.
- Click the Prefix List tab.
- Click Insert.
- In the Id box, type an ID for the prefix list.
- In the Prefix box, type an IP address for the route.
- In the PrefixMaskLength box, type the length of the prefix mask.
- Configure the remaining parameters as required.
- Click Insert.
Prefix List field descriptions
Use the data in the following table to use the Prefix List tab.
| Name | Description |
| Id | Configures the list identifier. |
| Prefix | Configures the IP address of the route. |
| PrefixMaskLen | Configures the specified length of the prefix mask. You must enter the full 32-bit mask to exact a full match of a specific IP address, for example, if you create a policy to match on the next hop. |
| Name | Names a specified prefix list during the creation process or renames the specified prefix list. The name length can use from 1 to 64 characters. |
| MaskLenFrom | Configures the lower bound of the mask length. The default is the mask length. Lower bound and higher bound mask lengths together can define a range of networks. |
| MaskLenUpto | Configures the higher bound mask length. The default is the mask length. Lower bound and higher bound mask lengths together can define a range of networks. |
