The Segmented Management Instance provides support for management interfaces that transmit and receive packets directly to and from the system native Linux IP stack. Unlike a traditional management interface, for example, a CLIP in the GRT that is part of the networking IP stack, Segmented Management Instance interfaces do not route packets through the networking IP stack.
The following management applications use the Segmented Management Instance directly to transmit or receive packets with segmented management interfaces and addresses.
The VSP 8600 Series only supports Ping, Traceroute, and NTPv4.
Segmented Management Instance Applications and Protocols
Client
Server
IPv4
IPv6
Digital Certificates
Yes
Yes
DHCP Client
Yes
Yes
DNS
Yes
Yes
Yes
FTP
Yes
Yes
Yes
Yes
HTTP/HTTPS
Yes
Yes
Yes
IQAgent
Yes
Yes
NTPv4
Yes
Yes
Yes
Yes
OVSDB protocol support for VXLAN Gateway
Yes
Yes
Yes
Ping
Yes
Yes
Yes
Yes
Yes
Yes
Yes
RADIUS Security (RADSec)
Yes
Yes
Yes
Yes
Yes
SSH/SCP/SFTP
Yes (SSH only)
Yes
Yes
Yes
Syslog
Yes
Yes
Yes
Yes
Yes
Telnet
Yes
Yes
Yes
Yes
TFTP
Yes
Yes
Yes
Yes
Traceroute
Yes
Yes
Yes
Yes
The following management applications do not use the Segmented Management Instance directly to transmit or receive packets, but can integrate with segmented management interfaces and addresses.
IPv4
IPv6
Link Layer Discovery Protocol (LLDP)
Yes
Yes
SynOptics Network Management Protocol (SONMP)
Yes
Sampled Flow (sFlow)
Yes
Remote Network Monitoring version 2 (RMON2)
Yes
The following management applications do not use the Segmented Management Instance and are deprecated in VOSS.
  • NTPv3
  • Remote Login (rlogin)
  • Remote Shell (RSH)
Operational Notes for UDP Management Applications
Management applications that use UDP, such as TFTP, RADIUS dynamic server, or SNMP can have restrictions when multiple Segmented Management Instances are configured with overlapping or asymmetrical routing.
The restrictions listed do not apply to TCP applications or if a single Management Instance is configured.
Asymmetrical routing can occur in any of the following scenarios. For the first two scenarios you can use the OOB or VLAN Management Instance IP address instead of the CLIP Management Instance IP address. Also, use FTP or SCP file transfer as an alternative because those protocols are TCP based.
In the third scenario, you can configure more specific static routes for networks originating UDP client communication to the OOB or VLAN Management Instance IP address if the CLIP Management Instance is also configured.
  1. Client communication to the CLIP Management Instance IP address is from the same subnet as the VLAN Management Instance.
  2. Client communication to the CLIP Management Instance IP address when specific static routes or default route with higher preference back to the client network exist on OOB Management Instance or VLAN Management Instance.
  3. Client communication to the OOB Management Instance IP address or VLAN Management Instance IP address that relies on a default route with a lower preference than the internal default route used by the CLIP Management Instance.
  4. Client communication to the CLIP Management Instance IP address is from the same subnet as the OOB Management Instance (even if the OOB port is down).
