Use the following procedure to display multiple host status for a port.
- Select 802.1X – EAPOL.
- Select the MultiHost Status tab.
MultiHost Status Field Descriptions
The following table describes values on the MultiHost Status tab.
| Name | Description |
| PortNumber | Indicates the port number associated with this port. |
| ClientMACAddr | Indicates the MAC address of the client. |
| PaeState | Indicates the current state of the authenticator PAE state machine. |
| VlanId | Indicates the VLAN assigned to the client. |
| Priority | Specifies the priority associated with this client MAC. This priority could be the Radius assigned priority or the port QOS level. |
| SwUniBindings Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series. | Indicates the Extensible Authentication Protocol (EAP) VLAN:ISID bindings that the switch represents as an hexadecimal value. |
| IsidSource Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series. | Indicates the origin of I-SID value:
| AclId Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series. | Indicates the dynamic Access Control List (ACL) on the specific port. |
| AceIdList Note: Exception: Not supported
                                        on VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series. | Indicates the list of dynamic Access Control Entries (ACE) on the specific port. |
| DynamicSettings | Displays the Dynamic settings received from the Remote Authentication Dial-In User Service (RADIUS) server. |
