After you enable or disable certain modes and functions, you need to save the configuration and restart the switch for your change to take effect. This section lists parameters and indicates if they require a switch restart.
The following table lists parameters you configure in the CLI using the boot config flags command. For information on system flags and their configuration, see Configure Boot Flags.
Flag support can vary across hardware models.
Table 1. Boot config flags
CLI flag
Restart
advanced-feature-bandwidth-reservation
Note:
Exception: Only supported on VSP 7400 Series and XA1480.
Yes
block-snmp
No
debug-config
Yes
debugmode
Yes
dvr-leaf-mode
Note:
The switch does not require a restart when you enable the dvr-leaf-mode flag, as long as there is no unsupported configuration on the switch.
No
enhancedsecure-mode
Yes
factorydefaults
Yes
flow-control-mode
Note:
Exception: Not supported on VSP 8600 Series.
Yes
ftpd
No
ha-cpu
Note:
Exception: Only supported on VSP 8600 Series.
Yes, the standby CPU restarts automatically. Modifying this flag does not require a system restart.
hsecure
Yes
linerate-directed-broadcast
Note:
Exception: Only supported on VSP 4450 Series.
Yes
ipv6-egress-filter
Note:
Exception: Not supported on VSP 8600 Series or XA1400 Series.
Yes
ipv6-mode
Note:
Exception: Not supported on VSP 4450 Series, VSP 8600 Series, or XA1400 Series.
Yes
logging
No
nni-mstp
Note:
Yes
reboot
No
rlogind
Note:
No
savetostandby
No
spanning-tree-mode
Yes
spbm-config-mode
Yes
sshd
No
telnetd
No
tftpd
No
trace-logging
No
urpf-mode
Note:
Yes
verify-config
Yes
vrf-scaling
Yes
vxlan-gw-full-interworking-mode
Exception: Only supported on VSP 7200 Series, VSP 7400 Series , VSP 8200 Series, and VSP 8400 Series.
Yes
