Use the following procedure to display the admin status of the Controller.
show isis spbm
The SPB-PIM-GW column displays either Controller, Gateway, or Controller/Gateway if the Controller and or Gateway functionality is configured.
Switch:1>show isis spbm
                                 ISIS SPBM Info
SPBM       B-VID      PRIMARY    NICK     LSDB     IP       IPV6     MULTICAST   SPB-PIM-GW
INSTANCE              VLAN       NAME     TRAP
1          10,20      10         0.00.77  disable  enable   disable  enable      controller
                              ISIS SPBM SMLT Info
SPBM       SMLT-SPLIT-BEB       SMLT-VIRTUAL-BMAC     SMLT-PEER-SYSTEM-ID
INSTANCE
1          primary              00:00:00:00:00:00
 Total Num of SPBM instances: 1
