This procedure only applies to VSP 4450 Series.
View port bridging errors statistics to manage network performance.
- In the Device Physical View, select a port.
- In the navigation pane, expand: .
- Select Port.
- Select the Bridging tab.
Bridging Field Descriptions
The following table describes parameters on the Bridging tab.
| Name | Description |
| InUnicastFrames | The number of incoming unicast frames bridged. |
| InMulticastFrames | The number of incoming multicast frames bridged. |
| InBroadcastFrames | The number of incoming broadcast frames bridged. |
| InDiscards | The number of frames discarded by the bridging entity. |
| OutFrames | The number of outgoing frames bridged. |
