Use CLI to verify your installed software. It is important to verify your software version before you place a device into a production environment.
enable
show software detail
The following is an example of the output of the show software detail command.
Switch:1#show software detail
                    software releases in /intflash/release/
VSPSwitch.X.X.X.X_GA
  MP
    UBOOT                            int009
    KERNEL                           2.6.32_int29
    ROOTFS                           2.6.32_int29
    APPFS                            VSPSwitch.X.X.X.X_GA
  AVAILABLE ENCRYPTION MODULES
    No Modules Added
VSPSwitch.X.X.X.X_GA  (Backup Release)
  MP
    UBOOT                            int009
    KERNEL                           2.6.32_int29
    ROOTFS                           2.6.32_int29
    No Modules Added
VSPSwitch.X.X.X.X_GA  (Primary Release)
  MP
    UBOOT                            int009
    KERNEL                           2.6.32_int29
    ROOTFS                           2.6.32_int29
    No Modules Added
Auto Commit     : enabled
Commit Timeout  : 10 minutes
