Use this procedure to generate a certificate signing request (CSR) and store it into a file. This CSR is required to obtain the offline subject certificate.
The following table defines parameters for the certificate generate csr command.
| Variable | Value |
| <subject-label> | Specifies the subject identity. |
The following table defines parameters for the certificate send-csr-to command.
| Variable | Value |
| <A.B.C.D> | Specifies the IP address for the certificate authority. |
| <remote-path> | Specifies the file path on the certificate authority. |
| <user> | Specifies the username for the certificate authority. |
