Configure a C-RP router to add it to the RP Set.
You can configure only one interface on a switch for multiple groups; that is, you cannot configure multiple interfaces for multiple groups.
Using the GroupMask value, you can configure a candidate RP for several groups in one configuration. For example, if you use a C-RP configuration with a GroupAddress value of 224.0.0.0 and a GroupMask of 240.0.0.0, you can configure the C-RP router for a multicast range from 224.0.0.0 to 239.255.255.255.
- In the navigation pane, expand the following folders: .
- Click PIM.
- Click the Candidate RP tab.
- Click Insert.
- Type the required information in each box.
- Click Insert.
Candidate RP field descriptions
Use the descriptions in the following table to use the Candidate RP tab.
| Name | Description |
| GroupAddress | Configures the IP address of the multicast group. When combined with the group mask, this value identifies the prefix that the local router uses to advertise itself as a C-RP router. |
| GroupMask | Configures the address mask of the multicast group. When combined with the group address, this value identifies the prefix that the local router uses to advertise itself as a C-RP router. |
| InterfaceAddress | Configures the IP address of the C-RP router. This address must be one of the local PIM-SM enabled interfaces. |
