| Feature | Product | Release introduced |
| MSTP-Fabric Connect Multi Homing | VSP 4450 Series | VOSS 7.0 |
| VSP 4900 Series | VOSS 8.1 | |
| VSP 7200 Series | VOSS 7.0 | |
| VSP 7400 Series | VOSS 8.0 | |
| VSP 8200 Series | VOSS 7.0 | |
| VSP 8400 Series | VOSS 7.0 | |
| VSP 8600 Series | Not Supported | |
| XA1400 Series | Not Supported |
The MSTP-Fabric Connect Multi Homing feature allows MSTP or RSTP network to be multi-homed into a Fabric Connect network, providing a loop-free topology. MSTP-Fabric Connect Multi Homing enables an MSTP network to be multihomed into the SPB Fabric network through single node-to-multiple nodes or multiple nodes-to-multiple nodes.
Important
You must enable MSTP-Fabric Connect Multi Homing before you establish multihoming with an MSTP network.
MSTP-Fabric Connect Multi Homing uses I-SID 16777003. The switch creates this I-SID automatically and it cannot be modified.
MSTP-Fabric Connect Multi Homing is supported on SPBM mode only.
