Display information about the files in internal flash memory on this device.
- Click File System.
- Click the Flash Files tab.
Flash Files field descriptions
Use the data in the following table to use the Flash Files tab.
| Name | Description |
| Slot | Specifies the slot number. |
| Name | Specifies the directory name of the file. |
| Date | Specifies the creation or modification date of the file. |
| Size | Specifies the size of the file. |
