Use the following procedure to display status information about the OVSDB controller.
- Click OSVDB.
- Click the Status tab.
Status field descriptions
Use the data in the following table to use the Status tab.
| Name | Description |
| IpAddress | Displays the IP address of a controller. |
| Protocol | Displays the communications protocol of a controller as TCP or SSL. |
| Port | Displays the communications port for the controller. Value range of 1 to 65535. |
| Source | Displays the source of the controller as learned or configured. |
| OperStatus | Displays the operational status of the controller. |
