The following table defines parameters for the router vrf command.
| Variable | Value |
| WORD<1–16> | Specifies the VRF name. |
The following table defines parameters for the mvpn fwd-cache-timeout(seconds) command.
| Variable | Value |
| <10–86400> | Specifies the timeout value. The default is 210 seconds. |
