The following table defines parameters for the ipv6 interface command.
| Variable | Value |
| address WORD<0-255> | Specifies the IPv6 loopback interface address. |
| vrf WORD<1-16> | Specifies a VRF by name. |
The following table defines parameters for the ipv6 ospf command.
| Variable | Value |
| <1-256> | Specifies the interface ID value. |
| area {A.B.C.D} | Specifies the IPv6 OSPF area, typically formatted as an IP address. |
| enable | Enables the OSPFv3 instance on the specific loopback interface. |
The following table defines parameters for the router ospf command.
| Variable | Value |
| ipv6-enable | Enables OSPFv3 for IPv6. |
