Configuring counter polling
Use this procedure to configure counter polling using the EDM.
This procedure only applies to VSP 8600 Series.
- Click sFlow.
- Click the Counter Polling tab.
- In the Index column, navigate to the slot and port where you want to configure sFlow.
- Double-click the Interval field and enter a value in seconds.
- Click Apply.
Counter Polling Field Descriptions
Use the data in the following table to use the Counter Polling tab.
| Name | Description |
| Index | Identifies the source of the data for counter polling. |
| Receiver | The sFlow receiver associated with the counter polling. |
| Interval | The maximum number of seconds between successive samples of the counters associated with this data source. A sampling interval of 0 disables counter sampling. |
