The following table defines parameters for the interface vlan command.
| Variable | Value |
| <1-4059> | Specifies the VLAN ID. |
The following table defines parameters for the interface GigabitEthernet command.
| Variable | Value |
| {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
The following table defines parameters for the ip address command.
| Variable | Value |
| <A.B.C.D/X> | Specifies the address and mask. |
