Configures the motion detector to control LEDs depending on motion near the front of the switch.
| disable | Disables the motion detector. |
| enable | Enables motion detector. |
| seconds | Specifies the number of seconds before the LEDs are turned off after motion is detected. The range is 1 to 600. |
Disable. The default number of seconds is 180.
When the motion detector is enabled, the LEDs are turned on only when motion is detected. The length of time in seconds that they remain turned on is configurable.
When the motion detector is disabled, the LEDs are always turned on.
To view the status and timeout settings, use the show power led motion-detector command.
The following command configures the LEDs to turn on when motion is detected and turn off 60 seconds after motion is detected:
configure power led motion-detector enable timeout 60
This command was first available in ExtremeXOS 12.6.
This command is available on the Summit X670 switch.
Print
this page
Email this topic
Feedback
