Configure VLACP on a port
Configure VLACP on a port to ensure there is end-to-end reachability. VLACP uses the Hello mechanism of LACP to periodically send Hello packets to ensure there is an end-to-end approach. After Hello packets are not received, VLACP transitions to a failure state and disables the port.
Important
Changes made at the global level override and reset all port level settings.
Use the following information to prevent flooding VLACP packets across a defaulted switch:
Use the default MAC address, 01:80:c2:00:11:00, for end-to-end connections that traverse an intermediate network.
Use the reserved multicast MAC address 01-80-c2-00-00-0f for directly-connected, peer-to-peer links.
Configure VLACP on port 1/1:
Switch:1# configure terminal
Switch:1# interface GigabitEthernet 1/2
Switch:1# vlacp fast-periodic-time 400 timeout short
Switch:1# vlacp enable
Use the data in the following table to help you use the vlacp command.
                             Variable  |
                             Value  |
                             enable  |
                             Enables VLACP for this port. The default is disabled.  |
                             ethertype <1536-65535 | 0x600-0xffff>  |
                             Configures the VLACP protocol identification for this port. Enter the type in decimal or hexadecimal format. The default is 0x8103.  |
                             fast-periodic-time <100-20000>  |
                             Configures the fast periodic time (in milliseconds) for this port. The default is 200.  |
                             funcmac-addr <0x00:0x00:0x00:0x00:0x00:0x00>  |
                             Configures the multicast MAC address used for the VLACPDU. Specify a MAC address in the format 0x00:0x00:0x00:0x00:0x00:0x00. The default is 01:80:c2:00:11:00.  |
                             slow-periodic-time <10000-30000>  |
                             Configures the slow periodic time (in milliseconds) for a specific port type. The default is 30,000.  |
                             timeout {long|short}  |
                             Configures the port to use the long or short timeout:
 For example, if you specify a short timeout, set the timeout-scale value to 3, and the fast periodic time to 400 ms, the timer expires within 1000 to 1200 ms. The default is long.  |
                             timeout-scale <2-10>  |
                             Configures a timeout scale for this port used to calculate the timeout. The default value is 3.  |
