SPBM Configuration Examples
This section provides configuration examples to configure basic SPBM and IS-IS infrastructure.
Examples and network illustrations in this document may not include your specific platform. Unless otherwise noted, the concept illustrated applies to all supported platforms. For information about high-level feature support, see Fabric Engine and VOSS Feature Support Matrix.
The following figure shows a sample greenfield deployment for SPBM.
For migration purposes, SPBM can coexist with existing SMLT configurations.
The following sections show the steps required to configure the Ethernet and MLT interfaces in this example.
SwitchC
PORT CONFIGURATION - PHASE 1 interface GigabitEthernet 1/30 encapsulation dot1q exit
SwitchG
PORT CONFIGURATION - PHASE 1 interface GigabitEthernet 1/5 encapsulation dot1q exit MLT CONFIGURATION mlt 1 enable mlt 1 member 1/21-1/22 mlt 1 encapsulation dot1q
SwitchD
MLT CONFIGURATION mlt 1 enable mlt 1 member 1/20,1/30 mlt 1 encapsulation dot1q
The following figure shows the IS-IS area information added to the network.
The following sections show the steps required to configure the global IS-IS SPBM parameters in this example.
SwitchC
enable configure terminal prompt SwitchC BOOT CONFIGURATION spbm spbm ethertype 0x8100 ISIS SPBM CONFIGURATION router isis spbm 1 spbm 1 nick-name f.30.13 spbm 1 b-vid 20 ISIS CONFIGURATION is-type l1 manual-area 30.0000 sys-name SwitchC exit router isis enable VLAN CONFIGURATION vlan create 20 name "B-VLAN" type spbm-bvlan
SwitchG
enable configure terminal prompt SwitchG BOOT CONFIGURATION spbm spbm ethertype 0x8100 ISIS SPBM CONFIGURATION router isis spbm 1 spbm 1 nick-name f.30.10 spbm 1 b-vid 20 ISIS CONFIGURATION is-type l1 manual-area 30.0000 sys-name SwitchG exit router isis enable VLAN CONFIGURATION vlan create 20 name "B-VLAN" type spbm-bvlan
SwitchD
enable configure terminal prompt SwitchD BOOT CONFIGURATION spbm spbm ethertype 0x8100 ISIS SPBM CONFIGURATION router isis spbm 1 spbm 1 nick-name f.30.14 spbm 1 b-vid 20 ISIS CONFIGURATION is-type l1 manual-area 30.0000 sys-name SwitchD exit router isis enable VLAN CONFIGURATION vlan create 20 name "B-VLAN" type spbm-bvlan
The following figure shows the IS-IS area information and interfaces in the network.
The following sections show the steps required to configure the IS-IS SPBM interfaces in this example.
SwitchC
PORT CONFIGURATION - PHASE II interface GigabitEthernet 1/30 isis isis spbm 1 isis enable exit
SwitchG
PORT CONFIGURATION - PHASE II interface GigabitEthernet 1/5 isis isis spbm 1 isis enable exit MLT INTERFACE CONFIGURATION interface mlt 1 isis isis spbm 1 isis enable exit
SwitchD
The following sections show the output from verifying the sample IS-IS SPBM configuration.
Checking Operation — SwitchC
SwitchC:1# show isis interface
                                ISIS Interfaces
IFIDX    TYPE   LEVEL    OP-STATE    ADM-STATE  ADJ  UP-ADJ  SPBM-L1    OP-SPBM-   ORIGIN   AREA   AREA-NAME
                                                             -METRIC    L1-METRIC
Port1/30 pt-pt  Level 1    UP         UP         1    1       10      (A) 10        CONFIG   HOME  area-9.00.02
Home: 1 out of 1 Total Num of ISIS Interfaces
Legend:
(A): l1 metric is automatically updated based on detected interface speed.
            SwitchC:1# show isis adjacencies
                                ISIS Adjacencies
INTERFACE L STATE  UPTIME   PRI  HOLDTIME   SYSID          HOST-NAME     STATUS   AREA  AREA-NAME
Port1/30  1  UP    1d 19:19:52    22      beb0.0000.7204    SwitchC      ACTIVE   HOME  area-9.00.02
 Home:   1 out of 1 interfaces have formed an adjacency
 Remote: 0 out of 0 interfaces have formed an adjacency
            SwitchC:1# show isis spbm unicast-fib
                          SPBM UNICAST FIB ENTRY INFO
DESTINATION          BVLAN SYSID          HOST-NAME    OUTGOING       COST   AREA    AREA-NAME
ADDRESS                                                INTERFACE
00:0e:62:25:a3:df   4000  0016.ca23.73df  SwitchG      1/30            10     HOME    area-9.00.02
00:14:0d:a0:13:df   4000  0014.0da0.13df  SwitchD      1/30            10     HOME    area-9.00.02
Home:   Total number of SPBM UNICAST FIB entries 2
Remote: Total number of SPBM UNICAST FIB entries 0
SwitchC:1# show isis spbm unicast-tree 4000
Node:000e.6225.a3df.00 (SwitchG) -> ROOT
Node:0014.0da0.13df.00 (SwitchD) -> Node:000e.6225.a3df.00 (SwitchG) -> ROOT
  Checking Operation — SwitchG
SwitchG:1# show isis interface
                                ISIS Interfaces
                                                             -METRIC    L1-METRIC
Port1/5 pt-pt  Level 1    UP         UP         1    1       10     (A) 10        CONFIG   HOME  area-9.00.02
Mlt1    pt-pt  Level 1    UP         UP         1    1       10     (A) 10        CONFIG   HOME  area-9.00.02
Home: 2 out of 2 Total Num of ISIS Interfaces
Legend:
            SwitchG:1# show isis adjacencies
                                ISIS Adjacencies
Port1/30  1  UP    1d 19:19:52   127  26         beb0.0000.7204    SwitchC    ACTIVE   HOME  area-9.00.02
Mlt1      1  UP    04:57:34      127  20         0014.0da0.13df    SwitchD    ACTIVE   HOME  area-9.00.02
 Home:   2 out of 2 interfaces have formed an adjacency
            SwitchG:1# show isis spbm unicast-fib
ADDRESS                                                INTERFACE
00:14:0d:a0:13:df   4000  0014.0da0.13df  SwitchD      MLT-1          10     HOME    area-9.00.02
00:15:e8:9f:e3:df   4000  0015.e89f.e3df  SwitchC      1/5            10     HOME    area-9.00.02
SwitchG:1# show isis spbm unicast-tree 4000
Node:0015.e89f.e3df.00 (SwitchC) -> ROOT
Node:0014.0da0.13df.00 (SwitchD) -> ROOT
Checking Operation — SwitchD
SwitchD:1# show isis interface
                                ISIS Interfaces
                                                             -METRIC    L1-METRIC
Legend:
            SwitchD:1# show isis adjacencies
                                ISIS Adjacencies
Mlt1      1  UP    05:03:59   127  21         000e.6225.a3df   SwitchG   ACTIVE   HOME  area-9.00.02
            SwitchD:1# show isis spbm unicast-fib
ADDRESS                                                INTERFACE
00:0e:62:25:a3:df   4000  000e.6225.a3df  SwitchG      MLT-1          10     HOME    area-9.00.02
00:15:e8:9f:e3:df   4000  0015.e89f.e3df  SwitchC      MLT-1          10     HOME    area-9.00.02
SwitchD:1# show isis spbm unicast-tree 4000
Node:0015.e89f.e3df.00 (SwitchC) -> Node:000e.6225.a3df.00 (SwitchG) -> ROOT
