BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Support Matrix.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
The VRF must have an RP trigger of BGP.
BFD provides a failure-detection mechanism between two systems. Use the following procedure to enable BFD for Border Gateway Protocol (BGP) peer groups.
Enabling BFD at the application level does not establish a BFD session. To establish a BFD session, you must enable BFD globally and at the interface level.Procedure
- Select BGP.
- Select the Peer Groups tab.
- Select Insert.
- Select BfdEnable.
- Select Insert.
Peer Groups Field Descriptions
Use the data in the following table to use the Peer Groups tab.
Name |
Description |
Index |
Specifies the index of this peer group. |
GroupName |
Specifies the peer group to which this neighbor belongs (optional). |
Enable |
Enables or disables the peer group. |
RemoteAs |
Configures a remote AS number for the peer-group in the range 0–65535. |
DefaultOriginate |
When enabled, the BGP speaker (the local router) sends the default route 0.0.0.0 to a group of neighbors for use as a default route. The default is disabled. |
DefaultOriginateIpv6 |
When enabled, the BGP speaker (the local router) sends the default route to a group of neighbors for use as a default route. The default is disabled. |
EbgpMultiHop |
When enabled, the switch accepts and attempts BGP connections to external peers that reside on networks that do not directly connect. The default is disabled. |
AdvertisementInterval |
Specifies the time interval, in seconds, that elapses between BGP routing updates. The default value is 30 seconds. |
KeepAlive |
Specifies the time interval, in seconds, between sent BGP keep alive messages to remote peers. The default value is 60. |
HoldTime |
Configures the hold time for the group of peers in seconds. Use a value that is three times the value of the KeepAlive time. The default value is 180. |
Weight |
Assigns an absolute weight to a BGP network. The default value is 100. |
MaxPrefix |
Limits the number of routes accepted from this group of neighbors. A value of zero indicates no limit The default value is 12,000 routes. |
NextHopSelf |
Specifies that the switch must set the NextHop attribute to the local router address before sending updates to remote peers. |
RoutePolicyIn |
Specifies the route policy that applies to all networks learned from this group of peers. |
RoutePolicyOut |
Specifies the route policy that applies to all outgoing updates to this group of peers. |
RouteReflectorClient |
Specifies that this peer group is a route reflector client. Note:
This parameter only applies to VRF 0. |
SoftReconfigurationIn |
When enabled, the router relearns routes from the specified neighbor or group of neighbors without restarting the connection after the policy changes in the inbound direction. The default value is enable. Enabling SoftReconfigurationIn stores all BGP routes in local memory (even non-best routes). |
MD5Authentication |
Enables and disables MD5 authentication. The default is disable. |
RemovePrivateAs |
Strips (when enabled) private AS numbers when the switch sends an update. The default is enable. |
SendCommunity |
Enables or disables sending the community attribute of the update message to the specified peer group. The default value is disable. |
| AfUpdateSourceInterfaceType |
Specifies the interface type. |
| AfUpdateSourceInterface |
Specifies the IP address used for circuitless IP (CLIP) for this peer group. |
Vpnv4Address |
Enables BGP address families for IPv4 (BGP) and Layer 3 VPN (MP-BGP) support. Enable this parameter for VPN/VRF Lite routes. |
IpvpnLiteCap |
Specifies (when enabled) that IP VPN Lite capability can be enabled or disabled on the BGP neighbor peer. The default is disable. |
RouteRefresh |
Enables or disables route refresh. If enabled, a route refresh request received by a BGP speaker causes the speaker to resend all route updates in the database that are eligible for the peer that issues the request. This parameter only applies to VRF 0. |
AsOverride |
Specifies that the AS Override parameter can be enabled or disabled for the BGP peer group. The default is disable. |
AllowedAsIn |
Specifies the number of AS-in allowed for the BGP peer group. The range is 1–10. |
IPv6Cap |
Enable or disable the IPv6 capability on the BGP neighbor peer. The default value is disable. |
Ipv6RoutePolicyIn |
Specifies the policy (by name) that applies to all network IPv6 routes learned from this peer. |
Ipv6RoutePolicyOut |
Specifies the policy (by name) that applies to all outgoing IPv6 route updates. |
Ipv6MaxPrefix |
Configures a limit on the number of IPv6 routes accepted from a neighbor. A value of 0 means no limit exists. |
BfdEnable |
Enables Bidirectional Forwarding Detection (BFD) for the BGP peer group. |
