View the multicast group trace to track the data flow path of multicast streams.
 - Select IGMP.
 - Select the Snoop Trace tab.
Snoop Trace Field Descriptions
Use the data in the following table to use the Snoop Trace tab.
 Name  |
 Description  |
 GrpAddr  |
 Displays the IP multicast address of the group traversing the router.  |
 SrcAddr  |
 Displays the IP source address of the multicast group.  |
 OutVlan  |
 Displays the egress VLAN ID for the multicast group.  |
 InPort  |
 Displays the ingress port for the multicast group.  |
 InVlan  |
 Displays the ingress VLAN ID for the multicast group.  |
 OutPort  |
 Displays the egress port of the multicast group.  |
 Type  |
 Displays the port type on which the snoop entry is learned.  |
