The following table defines parameters for the ip spb-multicast-policy command.
                                 Variable  |
                                 Value  |
                                 apply  |
                                 Applies the IP SPB Multicast Policy on route-map.  |
                                 enable  |
                                 Enables the IP SPB Multicast Policy on route-map.  |
                                 route-map WORD<0-64>  |
                                 Specifies the route of the policy. WORD<0-64> specifies the name of the policy.  |
                                 vrf WORD<1-16>  |
                                 Specifies the VRF name.  |
The following table defines parameters for the match command.
                                 Variable  |
                                 Value  |
                                 multicast-groupWORD<0-259>  |
                                 Specifies the multicast group for IP SPB Multicast Policy . WORD<0-259> specifies the name of one or more prefix lists, separated by a comma.  |
The following table defines parameters for the set command.
                                 Variable  |
                                 Value  |
                                 data-isid <1-15999999>  |
                                 Specifies the data services instance identifier (I-SID) for static I-SID routed multicast policy.  |
                                 rx-only  |
                                 Specifies the received traffic only, applicable to static I-SID routed multicast policy.  |
                                 tx-only  |
                                 Specifies the transmitted traffic only, applicable to static I-SID routed multicast policy.  |
