Configure CFM Nodal MEP
- You must configure a CFM MD, MA, and MEP.
Use this procedure to configure the CFM nodal Maintenance Endpoint (MEP). The Nodal MEP provides traceability and troubleshooting at the system level for a given B-VLAN. The Nodal B-VLAN MEPs created on the CP and function as if they are connected to the virtual interface of the given B-VLAN. Because of this they are supported for both port and MLT based B-VLANs.
Nodal MPs provide both MEP and Maintenance Intermediate Point (MIP) functionality for SPBM deployments. Nodal MPs are associated with a B-VLAN and are VLAN encapsulated packets. Each node (chassis) has a given MAC address and communicates with other nodes. The SPBM instance MAC address is used as the MAC address of the Nodal MP.
- Select VLANs.
- Select the Advanced tab.
- Select a VLAN with a type of spbm-bvlan.
- Select Nodal.
- In NodalMepList, specify the nodal MEPs to add to the VLAN.
- Select Apply.
Nodal MEP/MIP Field Descriptions
Use the data in the following table to use the Nodal MEP/MIP tab.
| Name | Description |
| NodalMepList | Specifies the nodal MEPs to add to the VLAN, in the format <mdName.maName.mepId>, for example md10.ma20.30. |
| NumOfNodalMep | Indicates the number of nodal MEPs assigned to this VLAN. |
| NodalMipLevelList | Specifies a MIP level list. |
| NumOfNodalMipLevel | Indicates the number of nodal MIP levels assigned to this VLAN that allows MIP functionality to be enabled on a per level per VLAN basis. |
