Use the following procedure to display SPBM nicknames.
 - Select SPBM.
 - Select the Nick Names tab.
Nickname Field Descriptions
Use the data in the following table to use the Nickname tab.
 Name  |
 Description  |
 Level  |
 Indicates the level at which the system displays this LSP.  |
 ID  |
 Indicates the 8 byte LSP ID, consisting of the SystemID, Circuit ID, and Fragment Number.  |
 LifetimeRemain  |
 Indicates the remaining lifetime in seconds for the LSP.  |
 NickName  |
 Indicates the nickname for the SPBM node.  |
 HostName  |
 Indicates the hostname listed in the LSP, or the IS-IS system name. The IS-IS system name uses global system name, if the host name is not configured.  |
