View the Metric Type of IS-IS Route in TLVs – Detailed
Use the following procedure to view the detailed information about metric type of IS-IS routes in TLVs in Link State Packets (LSP).
  1. Display the detail view of TLV 135:
    show isis lsdb tlv 135 detail
  2. Display the detail view of TLV 184:
    show isis lsdb tlv 184 detail
Viewing the metric type of IS-IS route in TLV 135
Switch:1#show isis lsdb tlv 135 detail
                               ISIS LSDB (DETAIL)
Level-1 LspID: 4072.0000.0000.00-02     SeqNum: 0x00000009      Lifetime:  1110
        Chksum: 0x31ce  PDU Length: 46
        Host_name: evp4k
        Attributes:     IS-Type 1
TLV:135 TE IP Reachability: 2
                Metric: 1 Metric Type:Internal  Prefix Length: 32
                UP/Down Bit: FALSE              Sub TLV Bit: FALSE
                IP Address: 15.15.15.72
                Metric: 1 Metric Type:External  Prefix Length: 24
                IP Address: 192.0.2.5
Viewing the metric type of IS-IS route in TLV 184
Switch:1#show isis lsdb tlv 184 detail
                               ISIS LSDB (DETAIL)
Level-1 LspID: 4072.0000.0000.00-03     SeqNum: 0x00000008      Lifetime:  1103
        Chksum: 0x3ce6  PDU Length: 72
        Host_name: evp4k
TLV:184 SPBM IPVPN Reachability:
                Vrf ISID:100
                        Metric:1 Metric Type:External   Prefix Length:32
                        IP Address: 192.0.2.3
                        Metric:1 Metric Type:Internal   Prefix Length:32
                        IP Address: 192.0.2.72
